Morimoto Announces NEW 2nd Gen XB Headlights for Gen2 Raptors
nikhsub1
Los Angeles
They actually seem ok but I will do more actual driving to see. Also something interesting. I hooked up the DRL wire to fuse 14 as others have suggested, works great. However, without the DRL wire my halos would stay on like the 'coming home' function for maybe 30 seconds after you get out of the truck. Now, with the DRL hooked to fuse 14 they IMMEDIATELY go off. Not sure how I feel about that, might want to move it elsewhere. Suggestions?
mattl600
Los Angeles
I noticed when I used fuse 35 per the manual my DRLs would stay on for quite some time after turning the car off.
I went to 14 and they now immediately turn off when I lock the truck which I prefer.
nikhsub1
Los Angeles
Did some driving tonight- the lights need to be rained up a bit still. Is there side to side adjustment?
CobraJay
Tweaker by trade
NE Ohio
I dont believe there is any adjustment aside from up/down on the gen2.
Still havent been out when it was truly dark yet, how do you rate the spread on these???
rayofsi
NYC
so i have my xbleds wired up to upfitter switch for now. I needed a full dark mode which wouldn't have worked if i wired it up to the fuse box. I think i also lost my bugatti startup sequence on remote start.
Anyone else have experience with wiring to upfitter?
TheTeej
Denver, Colorado
even with the upfitter left in the “on” position during remote start?
nikhsub1
Los Angeles
OK so I've noticed there are actually 3 brightness modes to the outer halos - dimmest is with the headlights ON. Next brighter is normal DRL mode. Brightest is with the truck ON but in PARK. I want to know if it is possible to somehow get the BRIGHTEST mode when acting as DRL. If someone can figure that out, beers on me.
rayofsi
NYC
ok fixed my issue lol, upfitter 5 blew the fuse. moved to upfitter 4.
i just removed the LVJ relay panel, and forgot to to a different upfitter.
need a 10A fuse for sure for the drl harness.
