Morimoto Announces NEW 2nd Gen XB Headlights for Gen2 Raptors
WoahItsRob
Virginia
Timing couldn't have been more perfect lol. The day after I ask about them, they end up shipping almost 2 weeks earlier then expected haha
Sent from my SM-N986U using Tapatalk
WoahItsRob
Virginia
Keep us posted about the light output tonight please.
I actually took her for a drive and it's definitely more output. The cut off line is very noticeable so I took a couple minutes getting used to that.
I still need to adjust my lights a bit but they are close to where they need to be.
I would say that the light is brighter and fuller and extends further then stock, fully encompassing my field of view down the road.
Deleted member 17706
Guest
What fuse are you all using for the Bugatti start up sequence? Lol mine came in today and am installing it now :)
WoahItsRob
Virginia
I was told any of the 10 amp ones that you can find. I have to wait on a different drl harness, mine wasn't the right size so I haven't hooked that part up yet
Guest
A couple of thoughts after driving around this morning:
1) they are definitely brighter than stock in low beam. The light is much more crisp and clean—something you would get with a luxury European vehicle. I need to adjust my headlights as they are mostly pointed to the ground, but I could still notice the difference from stock.
2) the sequential turn signal looks SWEET! Really like this feature. I had to unplug my sequential turn signal wiring in order for the sequential to work.
3) the amber ring that runs alongside the edge of the headlight seems to be a lot brighter than stock. As I was driving down a pitch black road, I was surprised to see the amount of amber light thrown on the sides of the road. Granted it’s not sufficient for a ditch light, but you can definitely see such areas better when compared to stock.
4) install was easy. Just make sure to take your time and follow what @4x4TruckLEDs.com states in his short wiring video: take the two resistors off (I switched out the third one as well).
5) pictures really don’t do the headlight justice—it looks even better in person.
Overall, I am quite pleased. I am up early in the morning and drive while it is still dark. The headlights look good, I don’t know if I would say they look better then OEM, but they definitely help me see the road better in situations where I can’t run high beams and my Baja Designs lights. Anybody need a set of OEM headlights? :)
*** Just as an FYI, my OEM headlights sold in 6 hours on eBay for $1500.
Ducc
Arizona
Received shipping notification yesterday - appreciate the quick turnaround 4x4!!
Question for those of you who installed the lights...
Did you find the angle/setting that you're happy with? From what I read here, there's something like 10 points of adjustment, so I'm hoping there's a consensus on the angle that's best (assuming a stock height truck)
