I just did mine over the weekend, EricM has posted all the Url's to do this repair. You do need a rivet gun as well, other than a 7mm, 8mm, 10mm, 13mm, t20,t25, 4mm allen key, phillips head screw driver, small flathead (for the tweeters,) More grease, Brake cleaner, and time. Take your time doing this, removing the headliner took 45 min, but the sunroof took 2 hours to do properly. The only thing I truly suggest in doing, in the video, the guy bench tests the sunroof to see if it is all lined up, but you still need to set your sunroof in the level closed position in the truck. So, put the sunroof assembly back in, with all the bolts and drain tubes, and then put the glass in. You then can cycle it with a 4mm allen wrench. It needs to be level and in the closed position, and, it is very difficult to know that position on a bench. Otherwise, its a good fix. Again, make sure the tracks are all the way forward. There are small padded stops they stop at, I also marked where the ends of the rotating cables were in the body by the motor for end reference.
