Modded White 6.2 in Orange County, CA
sonoma
Dispatch
FRF Lady
California
Since the frame is notched to give the truck more up travel, you have two options.
A) Cut up the bed significantly to allow for more tire clearance and then panel in new material to enclose those openings
B) Ditch the bed in its entirety
Okay, got it now.
Raptizzle
Raptizzle
FYT
Southern CA
Bumpdates on a couple little projects.
Seated heats all good to go.
Dual Battery Switch mounted and wired.
Dust lights wired up.
Thanks Ransom Racing for putting the final touches on the truck.
NickPic83
Rockland County NY
Why the dual battery switch ?
And not just permanently have both hooked up ??
Probably because if they both drain down while the truck is off your screwed. Now if one drains down u switch to the other and can still fire up the truck. Also if one battery fails with a bad cell it will drain the other one. If your out in the trails by yourself a dead battery can easily leave u stranded. Lots of guys with UTV's do this or just use a battery isolator
