Mirror tap or Fuse box?
3Dog
Gold member
Rocky Mountain high...
GREEN is Ground, BLACK is +12v switched. Photo courtesy of @FastEddie from this thread: https://www.fordraptorforum.com/threads/radar-detector-mirror-tap.62288/
Not on mine. Just to post more information, my '17 wiring is a little different. My 2017 Raptor with 802A doesn't have the black plastic cover for the wires for the mirror wiring, FYI, like others do. If that matters, which it may. Regardless, the taps shown in the picture above from @2020LeadFootFL (with credit to @FastEddie ) are in the correct location (position 1 for switched power, and number 4 for ground), same as mine - BUT my switched power wire is blue/brown and my ground is black/yellow.
Hope this helps others.
P.S. After much review on this topic, I am left with the impression that the guys at the assembly plant just grabbed the nearest spool of bulk wire when fabbing up the wiring harnesses. ;)
Tampa, FL
I think you’re spot on. At least they put them in the right holes.
