Mirror Spot Lights?
Vince
Alexandria, VA
Two questions on the mirror spot lights:
1. Are they manually adjustable?
2. Where is the switch located to turn them on?
Mark986
+1 Chris... now if we can only defeat the CRAWLING speed requirement.... there were a few times tonight where they would have been helpful around 45mph.
You actually can disable the speed limit on the mirror leds by jumping a wire to the module under the steering wheel.
Bombsquad68
Ab, Canada
Does anyone else find them kinda weak ? I can't see them being useful at much more than a crawl speed right now.
Would be cool to see a bright aftermarket version fron Rigid or BD and then do the mod to use at any speed .
GM3SF
This is actually a pretty great feature. I tried it with the mirrors folded backhand they give a pretty good amount of light aimed backwards.
