Does anyone know if the white side alley lights on the mirrors can be changed to come on at a higher speed other than the factory setting? The factory settings are too slow for real use.
My guess is you can do it with Forscan. There is a long thread about it if you do a search.
Can't be done with Forscan however there is a mechanical work around. Youtube search should show you the way.
