Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I have a standalone gauge/sensor but the vast majority of boosted trucks on here do not. I think the stock sensors are good enough. I just like to know what's going on with my engine.
Around 600hp on low boost and closer to 700hp on high boost setting. It "could" make into the 800's but I dont want to start needing to upgrade internals like rods or even oil pump and fuel pump.
A cam would get you more power at the same psi. However, why spend additional money when you can simply just turn up the boost if you want more power? I personally would not do that. Oil pump and fuel pump will not gain you any power, they are only if you need them at a certain power goal.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
