Meet my Beast
CFIT
Valencia, CA
I installed my plate based on that graphic, which was referenced in another thread a while back. This position allowed me to install my Baja Designs Onx6 light bar behind the lower grill.
What is your plate mounted to? Do you have a bracket of some sort, or is the plate mounted directly to the bumper? I've looked around for a mounting bracket designed for that location, but haven't had much luck.
gneissday
I could have used the the factory mount bracket that comes w/our trucks, but didn't because the plate would stick out further and possibly block some side light from the light bar. I just removed the lower grill cover and used two 3/8" bolts to fasten it directly to the cover.
max_Raptor
Looks like that part is only for "Gulf Cooperative Countries" (GCC) and isnt shippable.
2017 Ford F-150 Front Bumper Cover Grille | FordParts.com
It is mounted directly with no bracket
---------- Post added at 05:18 PM ---------- Previous post was at 05:17 PM ----------
You guys can use the dimensions in the picture I posted to create a template for the holes
lottp
Was it confirmed that there are no sensors or anything behind that would be blocked by the license plate on a fully loaded 802A?
gneissday
Just run no front plate like 80% of us lol
I see you are in So Cal, too. I have to park my truck on the streets of Santa Monica often and will get nailed in a heartbeat w/out a front plate. Maybe OC is more tolerant. I don't mind the side plate at all and it will look even better when I receive my 1960's plates in black and yellow that say "BAHA FUN".
dlbb
so cal
i am gonna mount mine on the drivers side. same way so thank you for details on how you did it.
