Got the following installed on the front end:
@svc Intercooler
@Addictive Desert Designs Stealth Fighter Bumper
- Rigid Radiance 40” Amber
- Smittybilt X20 Synthetic Winch
- Factor55 Fairlead
- Factor55 ProLink
- Switched to Cobb Stage 2 tune
Up Next:
- Waiting for Rigid SR 10” Amber flood lights to come in to use as fogs.
- Over break I’ll be designing custom covers for those that’ll let out more light and you know, be custom.
- Also over break designing a two piece skid so I can use actual nuts (not speed nuts) on the upper half and fairlead, then have access below if needed for oil changes and servicing the winch.
Also going to switch out the winch rope for one that’s about 10’ shorter. The X20 doesn’t sit perfectly centered. No fault to ADD for that, it makes sense for different winche shapes and different IC piping you have to work around, good on them for giving options and flexibility. But what that does in my situation is prevents the rope from spooling across the entire width of the drum after about half of it is spooled. It ends up rubbing a tiny bit at the end. I worry that if a bunch of mud/dirt gets up in there it’ll jam up when unspooling.
