M&R hood mount kit behind the grill.
Brute4s
Tuscaloosa Alabama
I have a Roush and wanted to put some lights behind the grill but the intercooler is in the way. After talking with Mike at M&R I ordered the hood mount kit planning on installing them behind the grill. I think they look killer. I took all the brackets off of the light and was able to use the bushings and bolts that were on the back of the light. I bolted them to the vertical struts behind the grill and they work perfect in the space between the headlights and the intercooler. Right now I only have 2 bolts in each but plan to make a square bracket to sandwich the strut for additional stability.
Brute4s
Brute4s
Tuscaloosa Alabama
update
Just finished with brackets. Used the bracket from the bottom of the light as a template, made it out of 1/4 inch steel. I used the stainless bolts that came with the lights and bolted the the grill strut. These are solid and have no movement....I have the aimed a little above where the high beams hit and they are bright as hell........thanks Mike at M&R for letting me give it a shot!!
MandR Automotive
Glad this setup worked out for you buddy. 2 of these lights put out around as much as a 40" lightbar
Evilmonkey
Olympia, Wa
I did something very similar. Mine are not intended for forward light but more to the sides at almost a 45 degree angle. I couldn't mount them low in the bumper openings because I've had that part of my bumper under the sand a few times. They really help out at night! I use the hood mount HID's and 40" for the forward lighting. Your setup looks great.
Gsteve
I have a 20 inch vx in the bumper and want something with more distance , how does yours do compared to the brights?
Huck
Chicago Sw Burbs
Brightness / raw lumens won't get you any distance.
If you want distance you need a different optic mirror design. And no one offers that in an led bar yet
Visionx came out with a bar that uses same technology as the light canon optic
Gsteve
which one is that?
