Lower control arm mount bracing
khcdave
South Brunswick NJ
As some may know the rear lower control arm mount is extremely prone to bending due to being weak and the bushing set up on the stock lower control arm. This was the case with David's truck. Here are some pics of how we fixed it making it much stronger
khcdave
khcdave
South Brunswick NJ
Thanks. Plenty of room to get in there with a wrench like normal. Designed them around the cam plates
Represent
Got any pics of them bent? Can't say I've seen a pic in the past, let alone "extremely prone to bending"
khcdave
khcdave
South Brunswick NJ
I didn't take any since it was a customers truck but to put it in perspective the control arm bolt was touching the front swaybar mounting bolt. Both rear lower brackets were bent back at least a inch while the fronts were perfect. The factory lower control arm front bushing has so much rubber it allows it to move back easily putting all the stress on the rear mount.
Mil T
Payson, Az
Any thoughts on selling the pieces for us DIY guys? Looks like you probably made a template. I'd certainly be a customer.
Mil T
