Hey guys.
I recently picked up an 18 Screw and looking to do some small wiring projects. I don’t have much experience in wiring so any pointers/recommendations would be appreciated.
I’m looking to wire a set of fog lights in the bumper openings to the Aux cables, hardware a dash cam to interior pass through, and hardwire a radar to pass through (also has a wired remote).
I have an understanding of where all the wires are and how the Aux cables work in these 18s. What kind of connections should I use? I’m aware of butt connectors, heat shrink, electrical wire... any recommendations?
I’m looking for a recommended path in the engine bay for the fog lights and for the path inside. I’m thinking about keeping the dash cam and radar on the passenger side of the rear view mirror to make it “easier” to run to the interior aux cables. Should I just tuck these or should I remove panels? What path should I go here? The only caveat as I mentioned was the radar “mute” remote that I plan on running up the center console/dash area on the passenger side and sticking it below the 12v/400watt port. I figure passenger side is easier if I’m wiring everything inside to the pass through cables and can keep it all on that side.
Thanks for any and all help. I did look around and saw some threads that had some advice. If there are any good ones that explain novice advice that I’m looking for, I’d appreciate that also.
