- Joined
- Jul 18, 2017
- Posts
- 2,982
- Reaction score
- 1,396
The main reason I want them is for off roading however, I was thinking about getting the amber small side corner lights as well with the 3 lights per side setup to help cut through dust and fog, with the center lights being white of the spot and flood or diffused lights. I need to do a bit more research to find the difference between flood/diffused/and SAE.
If you are looking at off-roading, then I highly recommend Baja Designs. Check out our Triple Fog Light Kits. Our brackets were built to handle anything you can throw at them off-roading. IN fact, we stand behind that with our Raptor Lifetime Guarantee. If you take a jump the wrong way and something happens to the brackets, they are covered.
I'd recommend
Squadron Pro Wide Cornering
Squadron Pro Driving/Combo
Squadron Pro Spot
If you are about off-roading. Aim the wide cornering below your low beams and you can get away with them on the road. They are not SAE rated, BUT if aimed properly you should have no issues. They'd work good to cover a wide/low pattern off-road. Then your driving/combos fill that in more followed by the Spots for down range (or go with the Racers but we find you don't need racers unless you are racing at night)
Our kits are $50 off right now for Labor Day
https://www.4x4truckleds.com/2017-f...ght-kit-w-baja-designs-lights-build-your-kit/
