Looking for a 6.2L Raptor owner interested in a camshaft swap... **discounted price**
SeaRaptor
New Jersey
It must be done by now, it was over a month ago. I wanna see the results it makes on a stock 6.2.
Andy@Livernois
Preferred Vendor
currently the project is on hold due to inadequate piston to valve clearance. Or initial hope was to design a cam phaser limiter similar to what we have devised on the older 3v for engines. Unfortunately there is literally zero PTV with these cams. As of now we are working with FRPP on either a revision of the parts, or an alternate solution with a different piston.
Thank you,
Andy
WarSurfer
DC
Zero PTV on 9.xx:1 compression?
Sounds like flycut pistons are in order. I was hoping to mill the heads for a half compression point but I guess that is off the table as well.
Andy@Livernois
Preferred Vendor
the problem here is the amount of material that would need to be removed is well beyond what we would be comfortable with. I personally think revamping the camshafts would make the most sense.
