GEN 2 List of the many problems during first 50,000 miles. Now the transmission is dead.
rabtech
Haleyville AL
51000 miles on it and the transmission just went batshit crazy. It went from 10th to 4th while i was running 70mph. Then it went to 2nd and sounded like it was hit in the ass with a semi truck. Then it immediately went to 7th then to 10th. You could drive it slowly if you put it in Manual and use your thumb to shift it gently. It will hold a gear then shift up or down at random but it seems like it has no brain at all. And it feels like the fluid pressure is maxed out. It will jar the dash out when it does shift.
I have had nothing but weird problems with this truck. I bleed Ford when you cut me. But the only reason I am holding on to it is because the other brands either look like crap or they sound like crap or the are outfitted with the cheapest crap interiors. .
I have had to have my front hubs replaced at 10,000 miles when they were trying to engage while driving down the interstate at 85mph. They lasted 4000 miles and then it started grinding again and then locking in one at a time while driving at highway speeds. I finally just plugged off the vacuum line and ran the truck with the hubs locked in for over 30,000 miles. Mainly because it only made my milage go down a bit to turn the front shafts. And the other reason it because the first time it took them weeks to fix the hubs.
Somewhere around 40,000 miles it would kill the battery overnight. I bought a jump box and kept it in the back floorboard just in case it ever got weak during the day. The dealer said that it must fixed itself but the next day after i picked it up it was dead in my driveway.. However magic must be in the air because after about another week it stopped draining. On the bright side I now I have this nice new jump box/air compressor that I don't leave home without…..
I have had a rear shock to completely discharge. I cant imagine having to carry it to the desert and run it on whoops. It has only been in 4wd a few times when i needed it to back up to a trailer or pull something on soft ground. So it just failed on its own for no reason.
So back to the current problem.
The transmission is dead. The first week they had the truck they changed the "transmission controller" and it didn't fix it. And then they wanted to change the "harness" and that didn't fix it… Now they called and said they pulled the transmission and want to replace the "torque converter"…
This is going to be a freaking month project for them…
And yes…. I was one of the first buyers. I got mine on Dec 31 2016.
And its sitting at Long Lewis Ford in Muscle Shoals.
And its always went there for service.
its vin is 1ftfw1rgxhfa23616
If Ford has a rep that looks over the post with problems I wish they would call Michael in the service department and get them a transmission on the way. They have screwed around with it for way to long.
Daxton
Sorry to hear but yes I would agree you need a new tranny. My 18 same as you described except at 5,500 miles. They replaced with new tranny after 30 days of other BS. You must have an ESP?
Get it fixed and get a ‘19, work a deal with your dealership. What I did and it feels night and day diff with more than just the tranny.
Good luck and love my Ford as well.
TxRap
I just got through the IWE issue myself. The tranny issue is scary. I agree with @Daxton to sell it off...
kid icarus
Nintendo
Why would you buy another of the same thing after all the problems? Plus all the other issues seen?
rtmozingo
North Texas
Your IWE problems are due to a leaking check valve, I'd wager. It was caught too late, so it damaged the front hubs. Although it sounds like the dealership never found the leak.
Shock is kind of weird...only seen two other instances of that, so bad luck there. You get a bad part every now and then. Same deal with the transmission, but there are more of those failures reported.
Oldfart
Maybe he looked at the Ram forums and saw the unbelievable list of issues. Like many different cabin leaks, electrical gremlins dealer can't fix, no parts available when dealer can finally find whats wrong, paint/fit issues, unsolvable electronic glitches, E-Torque problems, just to name a few. Less than 1/2 of new owners have no troubles! I wouldn't run around bragging about that. You can't be serious comparing the problems between the 2.
I've never heard of anything more ridiculous than a brand new truck that the factory can't make water tight!
rabtech
rabtech
Haleyville AL
Thanks for the replies everyone…
I have been a member here since my first raptor in 2012. I traded it for a Platinum and kept it till the new gen2 came out. I drove from Alabama to Lexington KY to pick it up at Glenn Ford. I love Fords. …
I think I'm just disappointed more than anything. I have the best longest warranty ford sells. I believe it is 125,000 miles and 7 years total. Its the premium or something like that.
Anyway,,, Thanks for not tearing me apart for never posting and then coming here and bitching about it… I guess I wanted to see how many other owners have had similar issues.
I hope they get it fixed this week but I'm not holding my breath……
rtmozingo
North Texas
It seems a select few have a handful of issues, and you unfortunately are one of them. The IWE situation is unfortunate as a $10, easily-replaceable part can lead to lots of damage if not caught early, but the other two issues are a luck-of-the-draw thing, and you got a bad hand.
There's two trucks I know of that have over 80k on them, lots of offroad time, with no issues and nothing outside regular maintenance. My truck has no issues at 22k.
6gun
Table Rock Lake, MO
Bummer about the tranny and other issues. Genius for buying Premium Care w/rental car. Repairs on mine have paid for cost several times over. I have a Gen 1 and have had tranny issues twice, first was torque converter leaking, was R&R'd and just had harness R&R'd. Also, A-Arms, ball joints, tie rod ends, heater mixer servo motor, sway bar links and probably other stuff as well i forget. Also just had an extensive rust repair on both rockers at 120K miles that Ford paid 75% of bill for (thank you FORD). Also had Rory rebuild the shocks on my own dime. Keep on em, escalate, write letters, call. Keep Ford on their toes. These are great trucks overall, but they are machines and I do not beat the crap out of mine, but it does get a workout from time to time. PS, I have had several GMC Suburbans that had regular tranny failures and would lose 3rd gear.....BMW's eat suspension parts for lunch, especially bushings. In the final analysis, I will have this truck for a long time to come unless SVT does something with the Bronco and if it looks worth a crap...i really wish i still had my 71.
