Lighted cup holders
LittlEvil
NorCal, East Bay
Trail_Rider I'm going to take a guess and say its your inverter. I bought a crappy cheap one $2.99 and a semi expensive one $12 from electroluminescent. I have been going 6 months now with no noise and no problems. When you find out the problem let us know, I'm interested in the outcome.
Trail_Rider
Danvers, MA
Ok, I figured out the issue, the wires from the inverter are real thin vs the wires they connect to. And the quick connects seem to fit the thicker truck wires fine but are loose on the inverters wires. So I just crushed them harder and the issue was solved.
Here is a photo of the install:
Mine seems to sit under the chrome trim more than the photos in this post and on the F150LEDS site. This is fine with me, its pretty much hidden from view when it's off and I really like it.
infinitereality
SLC IR/8
Louisiana
I came across the F150LED site last week on youtube and saw their install video. Seeing the video and what they sell, I knew it could be done way cheaper.
New 1M 2M 3M 4M 5M Colors Flexible El Wire Neon Glow Tube Lamp Light 3V 12V | eBay
I took a gamble and ordered this estimating it'd take 3ft. After reading @LittlEvil what I ordered should be perfect.
It came in the beginning of this week, but plan to install this weekend. My plan was to use hot glue gun to set the wire in place. I've recently discovered hot glue works better than epoxy or silicon in some recent projects, cools quickly and easily removed.
For what it's worth I wouldn't ever order anything from them, you can find same stuff easily on Amazon or eBay and save a boat load of cash.
infinitereality
SLC IR/8
Louisiana
Thanks again LittlEvil for the information. I followed your advice and cut the stock area down a little bit before installing the el wire. Used hot glue to attach, just went around and glued between cupholder and el wire. Snapped it all back together and quick connect on the proper wires. Love the look and matches stock lighting great! Not too bright or dim. Definitely worth the $5!
Five-O Donut Hole
Northern Illinois
Would you mind giving me a run down of the tools and materials you used along with where you purchased them. Your Install looks the cleanest I've seen and would like to replicate that. Thsnks
infinitereality
SLC IR/8
Louisiana
This is all you need, these are options: blue/DC 12V controller/1m
I think my install came out like everyone else, maybe angle I snapped picture this morning on way to work. Honestly just follow just like LittlEvil did, that's what I followed for mine. Only thing different is a hot glue gun, just makes easy work of attaching el wire. But adhesive is totally up to you.
Nick@Apollo-Optics
Any issues/noise with the included inverter?
