Light Wiring Advice
dblack
Alabama
I just ordered a triple bezel kit from Baja Designs and it is arriving tomorrow. I am somewhat familiar with electrical wiring, but wanted input from the experts before I start my install.
I ordered the following:
  • Baja Designs Squadron Pro
  • Baja Designs SAE Wide Cornering
  • Baja Designs S1 Wide Cornering (amber)
My first question is which wire bundle do I need to unwrap? I see it changed between years and want to grab the right one the first time. It's a 2019.
My second question is which up fitters would you recommend for which lights? I want them all on separate switches.
My third question is has anyone used Posi-Products Wire Connectors? I have used them for other things, but was thinking they may be a good option because 1) they allow me to keep the factory wiring length in tact and 2) they are easily swappable and removable.
https://www.crutchfield.com/p_669PP616/Posi-Products-Wire-Connectors-for-18-to-20-gauge-wire.html
Lastly, if I go that route, is 18-20 gauge the correct size? I know the upfitter wires are small.
Thanks in advance!
OffroadAlliance.com
Boston, MA
Switches 1 and 2 are 15 amps, 3 and 4 are 10 amps, 5 and 6 5 amps. We recommend using switches 1-4 and 14-16 gauge wire for switches 1-4 and 18 for switches 5-6. Our kit does come with instructions, we've got a Youtube installation video and here's the link to the instructions as well:
Link ---- >>> INSTALLATION
Here's a picture of the wiring:
dblack
dblack
Alabama
Appreciate that info. I assume my order came with your wiring harness, so I shouldn't need any additional wire?
So the Squadron Pro driving/combo is listed on the BD site at 2.90A per light? So most likely Switch 3-4.
SAE is listed at 1.6A per light?
S1 wide cornering (amber) is listed at 1.45A?
Seems like the best option would be Squadron Pro on 4, and the SAE on 5 and S1 on 6?
OffroadAlliance.com
Boston, MA
The wire is pretty darn thin on switches 5 and 6. If you're not planning on using all the switches, we recommend sticking with 1-4. And yes, the kit comes with a wiring harness.
Thanks in advance!
i would avoid those connectors you listed. while they do work, they are not weatherproof. they will corrode and eventually fail and possibly split the wire you tapped into.
dblack
dblack
Alabama
I'm not sure I follow. They are listed as waterproof and don't tap into any wire. The upfitter wire feeds into one end and the wiring harness wire on the other end.
took another look at the connector. different connector than i first thought, however over the years i have seen many fail and many corroded wires with these connectors as well. not as bad as other connectors though
sixshooter_45
Arnold
Use dielectric grease at the connections. Plugs.
Let there be Light!
Dielectric grease is silicone-based grease that repels moisture and prevents electrical connections from corroding.
The grease is a non-conductor of electricity. You are therefore advised not to apply it on mating surfaces of electrical connection.
At the connection is the key, plugs as you stated.
JefferyGT
Vantucky
Sounds good. I've used it all my life with fantastic results.
