Light weight 2 piece rotor f/r
crash457
I'm Batman
St. Louis, MO
"Allows the disc to expand and contract and prevents the disc from cracking or warping"
That is what it says, but they are also the manufacturer. I don't see how it allows any more expansion and contraction than a convectional drilled and slotted rotor. Considering it is essentially a drilled and slotted rotor with the holes drilled in the slots, seems like the thinner are around the drilled holes might be a weak spot.
Huck
Huck
Chicago Sw Burbs
There are no drilled holes....
the slots are cut into the internal vanes
BajaFred
To "cut" the holes into the slots, they are manipulated after casting ie just like drilled rotors
Slotted only is still the structurally strongest option behind a solid rotor
Huck
Huck
Chicago Sw Burbs
And in your mind a square block of material
Is stronger than a hollow bar too huh?
BajaFred
Look, I get it you want to be Captain of the rotor group buy
That's fine, but get educated and don't be an ******* about it
I've QFT your original post since you lost credibility right there
Ask RB how those "cut" holes get into the slots
To your question, yes a solid 3" cube of steel is stronger than the same 3" cube hollowed out - is this really a question
