Light throttle noise Gen1 IWE
Northern VA
Figured I'd post this for others looking for rattling/ pinging type noises, it's well documented all over but I had a hard time narrowing it down initially. I searched and searched and couldn't quite find this noise
It was present on light throttle usually 3rd-6th gears
But eventually I found info OF 9here and tested the IWE ports/vacuum and lines etc and determined that the passenger line was broken
Crazy that it had enough vacuum to be able to pull the drivers side most of the time while the passenger side had zero and was locked and only made the noise under certain light throttle position and consistently through heavy throttle but harder to hear.
I tested the 4x4 functionality and it seemed fine because the switch and vacuum was only engaging the one side, otherwise in 4x2 one side was spinning and the other wasn't and acting like an open diff I guess.
I tried to upload the video here for others searching but it was too large - here's a YT short of my noise
Also found this that closely resembled the noise @ 1:54
Thanks
Hope this helps someone new to Raptors that's not that familiar with them
Other search terms rattle rattling marbles pinging grinding
Gumby
Nashville
youreaspeedemon
Northern VA
I fixed the vacuum leak and it's good now. I think I may have referenced that post as well as other YouTube videos for testing. Also ordered a new Solenoid and vacuum line with check valve to have as spares
It's getting a little better mpg as well, but I idle too much with the a/c on so it's negligible.
