WannaRaptor62
- Joined
- Jan 2, 2011
- Posts
- 159
- Reaction score
- 3
What have you guys done to help prevent theft of your expensive LED light bars?
novel idea on the cable, but it's so thin gauge if they're bringing a ratchet and wrench to unbolt them, a pair of dikes will snip that in a heartbeat.
but if somebody wants them they'll get them, and it may be enough to deter someone with that extra step.
if you have an alarm system, you could run a wire through the same way, and have it wired to a relay and to ground, if the circuit is broken by snipping the wire to undo the bolts, the alarm is set off.
