NickPic83
Yes I do NickPick83.
so if the wires on the new light are labeled all u have to do is test each wire on the truck goin to the tai light bulbs. turn the blinker on and test each wire. once u find the which wire gets voltage on it, u can tap into it in whatever method u choose. then u can set the ebrake and chock the tires and put the truck in reverse and test for power, then u will know what to tap into for reverse and then go on from there.
