ATRaptor
- Joined
- Feb 16, 2018
- Posts
- 68
- Reaction score
- 32
Not tuned. No extra boost. Just the intake, DP, adapters and 542’s gapped at .028. I swapped out the original plugs last night and drove around to see if that affected the coolant temp. It did not. So I put the 542’s back in. This morning I threw the misfire warning. Have not had a chance to get the code read yet. Maybe I’ll close them to .025 to see if it stops the misfire. I’m getting the code read after work.
71 degrees this morning and the truck still ran warmer. Hit 221 at one time. But it quickly drops back to 202-205 off the boost. Hell even under 200 downhill. Averaged 210-212 degrees.
Roger that, another dumb question so I apologize- but you're sure it was a misfire code I.E. the check engine light was flashing? Usually if its JUST a misfire the light will flash and then turn off, but you're saying you still have a light on?
I've got nothing on the truck running hot but I will say a lean condition can cause a car/truck to run a little hotter than usual, for what its worth.
