What size tires are those? Why I ask;
The original Gen 2 Raptor tire size is 315/70/17. BFG makes two Ko2 tires in that size, part number 58424, 315/70R17 113/110S, load range C, and part number 08806, 315/70R17 121/118S, load range E.
The load range C tire, part number 58424, is the original equipment tire for the Raptor and is a 6 ply rated tire. The load range E tire, part number 08806, is a 10 ply rated tire.
Both of those tires are "mud and snow" rated, and carry identical "M + S TRACTION" with three peak and snowflake markings.
But I don't think either of those are DT tires (I freely admit I could be wrong, but I don't think so). DT standing for "Different Tread", meaning the tire has a different, harder wearing, rubber in the tread region.
The 6 ply tire rides soft and quiet, but is fairly easy to push objects through when off road. I recently replaced my original 6 ply tires (at 29+k miles) with the 10 ply, load range E, version. I find the 10 ply tire a bit harder riding, and I do not have enough miles on them to even guess at wear comparisons.
I rotate every other oil change, but I try to change oil at 3000 miles, sometimes I procrastinate a bit and don't get around to it until almost 4000 miles. So the tires are rotated every 6000 - 8000 miles. I do cross rotate, to even out wear.
Although I replaced the the first set at ~29k miles I still think I got acceptable wear and life out of them. Several thousand of those miles were off road, and I am not particularly gentle on tires even on road. I am also in the desert heat, however near Death Valley CA, a bit west of you.
I find for best, most even wear, and best ride I have to run both types of tires a bit light on air. With the original tires I ran 38 lbs front and 35 lbs rear, I wanted to run a couple pounds less than that, but found the TPMS tripped on cool mornings, as the 35 lbs sometimes dipped below 32 lbs on those mornings. So far I am running the 10 ply tire at the same 38F/35R, but will probably try 36/34 and see how that goes. Even at 38F/35R I was getting mild indications of over inflation (slightly increased center wear).
T!
