KO2 tire life, pics
2018 supercrew with 27k miles bought in October 2017. I've started getting a lot more road noise from my tires and just wanted some opinions on whether my ko2s are ready to replace or if they still have a bit to go. They have seen a fair amount of gravel, dirt roads, etc from a lot of hunting trips. Image 300 is rear, other is front. I have rotated them every 8k. Thanks!860825f6f9136163e2ededca50fb2eb3.jpg6706994b9209bf1f7d16e1d79681e491.jpg
Sent from my Pixel 2 XL using Tapatalk
taco-13
Long Island, NY
At 15,000 miles my ko2s starting making alot of noise. At 75-80mph they would cause the turn signal lever to vibrate and make a weird high pitch noise. At 38,000 miles my tires looked about what yours look like in the pic. If I remember right they were 6/32nds all around. I just purchased new ko2s. They are so quiet now. No vibrations or noise at any mph. They stop so much better and dont spin around every turn.
goblues38
STL
OP was rotating every 8k. Where you doing that?
I think I would be pleased to have that much meat on the tires left at 38k miles. To me they look like they could go another 5k, if the noise was tolerable.
dhmcfadin
There are two different tread compounds for KO2’s.
One is called D/T (more dense tread compound- comes with 50k warranty- no snow rating)
The other is non-D/T (softer tread compound- no 50k warranty- does have snow rating)
Factory Raptor KO2’s are NON D/T. That’s why you are seeing increased wear and noise. The non D/T won’t last as long but is better off-road (supposedly)
taco-13
Long Island, NY
I was rotating every 5k. I believe my tires could have gone atleast another 5k. I was just sick of the noise and the feel on the highway. I picked up the replacement tires from Costco. They are same same c load rating as what came on the truck.
taco-13
Long Island, NY
Your correct. Info from the tires I got at Costco.
BFGoodrich's toughest All-Terrain tire. Ever.
Tire Benefits
  • 20% Tougher Sidewalls: Featuring race-proven CoreGard™ Technology to take on the toughest road hazards with confidence. *
  • Longer Treadlife to extend your adventure.**
  • Aggressive All-Terrain traction to confidently get where you want to go.***
  • 50,000 Mile Manufacturer's Treadwear Limited Warranty on select sizes.
Tire Features
  • CoreGard Technology: 1) Split & bruise resistant sidewall rubber, derived from BFGoodrich's race proven Baja T/A®KR2 tire. 2) Increased rubber thickness, extending down the sidewall to protect more of the critical sidewall failure zone. 3) Advanced Deflection Design deflects protruding objects from snagging & splitting the sidewall.
  • 1) Locking 3-D Sipes provide increased tread block stability, for more even wear over the long haul. 2) Advanced tire footprint shape results in more evenly distributed stress, for longer more uniform wear.
  • 1) Serrated Shoulder Design provides increased mud, snow & rock traction, especially in aired-down driving situations. 2) Interlocking Tread Elements maximize traction and handling on- and off-road by stabilizing the tread center and providing biting edges for improved traction. 3) 3-Peak Mountain Snowflake Rated: Exceeds Rubber Manufacturer Association (RMA) Severe Snow Traction requirements.
  • The following sizes offer a 50,000 Mile Manufacturer's Treadwear Limited Warranty but don't carry the 3 Peak Mountain Snowflake Rating. These KO2's carry the DT designation.MSPN 42353: LT267/75R16 123/120R MSPN 72596: LT285/75R16 126/123RMSPN 89442: LT285/70R17 121/118RMSPN 23104: LT275/70R18 125/122RMSPN 16152: LT275/65R20 126/123RMSPN 88846: LT285/65R20 127/124RNote: These same sizes are also available with the 3 Peak Mountain Snowflake Rating but without the 50,000 Mile Manufacturer's Treadwear Limited Warranty. These sizes do not carry the DT designation.
goblues38
STL
Thank you. I saw the 2 different load ratings for the same tire on tire rack, but never knew the details on why they were different.
Thank you all for the replies. I think I'll start shopping around. The noise annoys me more and more every day.
lawdog
I've got 19K on mine, decent tread wear, but horrific wet traction.
dhmcfadin
The D/T tread lasts well over 50,000 miles and the wet performance is improved in my opinion. I would never buy the non d/t.
