Waiting to see more!Must post pics and video to let us enjoy sound!
I plan on doing a full video, it will be a few weeks before I get it edited together etc. Install I'm doing hopefully Thursday.Can you describe where everything goes? Or I can wait for the install pics.
i got mine from Texas Air Horns (Train Horns) remade a bracket to mount to the radiator support (an Tapped Threaded to mount) facing down . an a 1'x1' sq. made a cross brace from frame rail to frame rail an bolted then welded a tab to mount to the bum. bracket ALL under the hoodFigured I'd start a thread now. As a Pre-tester, I just purchased the kit and received it yesterday. Won't have time to install until late next week but I did get started with the bench work. Impressive kit. Build quality is excellent. Way more components than what I was expecting. I'll update as I move forward.
The kit I'm installing is for Gen 2 SCREW, it's the upgraded Demon 730 horns with the Ultra Blast Master upgraded valves. IOW: as loud as it gets.
I'm wiring everything to Aux3 upfitter. Turning that switch on will essentially arm/power the system, I'll explain how in the video I make up. Here is my button.... It's kick ass. I had it wired and ready to go months ago.can't wait for mine to get here after seeing some initial posts. I made it into part of the second test group shipment. pretty excited about the onboard air capabilities as well.
Do you guys plan on wiring the compressor up to an aux switch in the cab or do you plan to wire into the key switch as the instructions show?
