Kleinn-TRAIN HORNS Built just for your RAPTOR.
unw153
Couple of questions:
I have the SVC Bumpstop kit, will this interfere with the horn installation under the bed?
Based on the specs for the 234/734, appears the only difference is the horns themselves (ABS vs. Steel), am I missing something? Does the hornblaster upgrade fill the gap?
Can you please provide pricing for both systems? I want the 734, but have other truck expenses before TRR.
Thanks!
SilentShooter
Siesta Key, FL
The 734 Horns are not the same as the 234 horns. The 730/4 horns are the Kleinn Demon horns which are a different size as well as being metal compared to the 230/4 horns. The Demon horns are 158.8 db vs 230's 153.3 db rating. The solenoid with each is different as well. With the Demons you can also go with the Ultra Blaster solenoid for even louder output but will be shorter blast as it uses more air
R
RSiWORKS
S.C.S. Michigan
Thanks!
pm sent.
R
RSiWORKS
S.C.S. Michigan
Get an Additional 10 %OFF
my websites already low prices.
Kleinn Train Horn kits 220,230,234,730, & 734
From now till the end of April.
Just visit my store under Kleinn Horns and use coupon Code: RSIROCKS at check out.
For info on these kits visit the first page.​
:hitit:
R
RSiWORKS
S.C.S. Michigan
:hitit:
Bump
triggerfish
Well I ordered my Kleinn 734 kit and should have it in hand on Wednesday. Now I just need to figure out where to get it installed and how to wire it.
I'm thinking of having the lead wire wired up to my control panel, ie, aux4, that way I can turn on/off the compressor as I wish.
