Kicker Sub Upgrade How-To
brettmess24
Waiting to hear back, will update you all.
Sweet thanks!
I'm thinking those of us with the Sony system can use whatever system we can find as long as it's the screw or scab sub I beleive there all the same. Difference being the plug and play interface which I don't believe we can use anyway.....
Thoughts? Anyone know for sure?
DezertRacer
Las Vegas,NV
Im installing the system now, using the splice and plug method to the factory sub connections. if you get the ultimate package . You can use all 4 door speakers and the sub with amp. you will just not use the other amp that comes with the kit for the door speakers. the amp in there now will work with the nav and sony system. Also as stated above you will need to cut the plug off the kicker harness and just splice into the sub wire plug. I will post pics shortly .
brettmess24
Cool! So what your saying is if I were to buy the full system it doesn't matter which one I get?
Because the amp that I would not be using is the only difference? So I could use the four speakers and sub and be good?
DezertRacer
Las Vegas,NV
Correct to a point. you need the system for the supercrew, so the sub is positioned on the correct side. b ut you can get the big system with the door speakers and the sub and use it with the MFT . you just won't use the separate amp that they have for the door speakers .
brettmess24
Yes as long as I get the supercrew version it doesnt matter what system I buy.
They sell two full kit systems one for 8" or 4.2" screen and one for the "base" system. Im guessing the difference is in the wire harness where it connects to the actual head unit to the amp for the four speakers.
So for us not using that amp to power the four speakers it really doesnt matter what system we buy as long as its for supercrew or supercab.
Hope that clears up any confusion....ha
