GEN 2 Key On Power Behind Rear Seat
Raptus
Raptus
Northern, CA
Thanks, ordering it now.
Lockitt POSI-TAP Assortment Pack wire connectors 10-22 AWG $9.94
Jay Z
Monroe Twp NJ
I've got a 2018 Crew Cab and I'm installing a pair of QTP electronic cutouts right after the resonator and before the muffler. In a perfect world I will not modify anything past the resonator exhaust tubes. This way if I want to go back to the OEM exhaust system I just need to replace the resonator.
I'm using a wireless controller that I will program to the garage door openers and mount behind the rear seat. I found a great way to run the wiring from the electronic cutouts on the exhaust system into the cab behind the rear seats and I found a 12V hot wire but it is always on. Has anyone found key on power behind the rear seats? If so, I'd love to know which wire. :)
Have a Happy 4th of July weekend!
John
After you are done with the install can you post a video of exhaust open? I would like to hear how it sounds.
Raptus
Raptus
Northern, CA
It should sound similar to a muffler delete kit when fully open. The nice thing about the QTP exhaust valves is they can be partially opened so you can adjust the noise to some degree.
