One thing you will want to check is the plastic oil pan. Mine was cracked and leaking very early on.
OP, congrats. Don't listen to this idiot. Most people with a Gen2 probably have a plastic pan, it's generally a non-issue.One thing you will want to check is the plastic oil pan. Mine was cracked and leaking very early on.
17's and half of 18's have them. Other half of 18 and all 19's have the metal pan. Ford switched to metal why? Because the plastic pans broke. Design problem solved. Mine is a plastic leaker, and many others have it. It has to be a huge problem if Ford swapped to a more expensive part.
Jazzie - you need to go bark up another tree... Or hide in a corner and sob away your poor decisions regarding your vehicle purchases. Mine are all figured out and all is good.
