just bought 2 BADBOY 519 mini air horns.. advice
sniperm
sniperm
I did some editing Sniperm!!!
So I'm getting shit for my wife about being on the forum and not giving my complete undivided attention to her. LOL
But anyway did you get it?
I'll try again,
You take the two term 30 wires tie them together each one with it's own 20 amp fuse and attach to the power block term on the fuse box.
Then run each term 87 wire separately to each horn + wire. and run the grounds to truck from air horn.
Tie the two term 86 wires together and splice into one of the OEM wire + , tie the two term 85 together and splice into the OEM wire -
(if I remember correctly top to bottom is + to - and right to left is + to -)
So in sort, term 85 and 86 will not draw any amps (just a couple of mil amps to throw the micro switch) to close to circuit between 87 and 30
Let me know if I'm still confusing you.
Thank you for the help!
Im out right now.. but Ill try to see if i understand anything..
Do i just wrap the wires around stuff? and use electrical tape?
---------- Post added at 02:15 PM ---------- Previous post was at 02:12 PM ----------
what is 85 and 86? the slot number? or fuse number?
MTF
Celebration, Florida
The slot number.
That would work fine just stripping away the insulation and wrapping the wires around nice and tight and tapping it up good, this is for the OEM horn wires.
Not the best way but will work, if that's all you have.
As for the + terminal stud and grounds you're going to need the solder less connections and start crimping.
Pick up a kit at Auto Zone or some place like that.
sniperm
sniperm
okay.. IM about to go down and try this.. on the Fig.D the 20amp fuse.. do i just tie one side and other side to battery?
MTF
At-a-boy! if you don't own a crimper get one. And get some wire loom to make it look neat! And some plastic wire ties. LOL
sniperm
sniperm
Ahhhhhhhhhhh.. fuking no luck today..
They dont ahve the ones with out the switch..
Guess im going to order it online and wait.....
btw, this is what the wiring kit looks like...
