TheWolf
@TheWolf Only thing I can think of is to ensure that the longer hose with the check valve in the middle is oriented properly. The arrow should be in the desired direction of airflow which would be toward the intake. Beyond that, make give your connections a good tug to ensure they are connected completely. It's easy to get the connector on most of the way without it actually clicking past the ridge on the outlet/inlet for the valve cover and intake respectively.
That is the problem. I did not notice that was a check valve, just figured it was a swivel. Thanks!
Now, what kind of damage could have been done by not having crankcase ventilation?
And maybe I missed this in the previous posts, but why does this hose have a check valve? Neither the OEM hose or the JLT have a check valve.
