Joined the Raptor Family
K
Kevin LaChapelle
Redmond, WA
Damn that’s really nice and custom. Can I send you some switches to do? LOL
Looking good!
I’d consider it. Depending on how it looks installed I’ll know if I need to replace the stock leds with brighter ones and therefore the effort needed to produce these.
K223
Florida
Keep us posted. True you will have to see how things illuminate. Good start though.
K
Kevin LaChapelle
Redmond, WA
I decided to reduce the font a smidge to keep the letters away from the edge of the switch. This helps because there is a lot of material to remove at the edges in order for them to be backlit correctly. Here is the switch after I reduced the font size from 10pt to 9pt and laser engraved a new set. I then used smaller end mills I ordered to be able to do a better job of removing the black plastic on the interior of the switch toggle. I will have a picture of them lit up later as I still need to get them to the shop where my truck is.
K
Kevin LaChapelle
Redmond, WA
Plugged them in and I like how they look when the switch is activated. I will get a picture when it is dark out of how they look when in the off position at night.
sixshooter_45
Arnold
View attachment 155242 View attachment 155243 View attachment 155244
With all that material removed from the front of the switches I would guess that you'd have to be careful when flipping the switches on.
Do you think after many cycles that it's possible that you would push the label through the opening? I guess it wouldn't be an issue if you're careful and cycle them on pushing on the lower edge of the switch only.
K
Kevin LaChapelle
Redmond, WA
Here is a switch I cut in half to see if the white plastic went all the way through. As you see the switch is predominately white plastic with a thin layer of black on the outside and most of the inside (they didn't put the black plastic on the inside where the AUX 1..6 labels are). The only plastic I remove is the black layer on the reverse of the face of the switch. There is still lots of plastic left and they don't feel any different and have no flex.
K223
Florida
View attachment 155278View attachment 155279
True, Structural rigidity should still be well intact. Coming along nicely.
