GEN 2 JDM Engineering NEW Tune on the market!
highway420
Ok, so we only need to un/reload the BCM module?That is better than the 10 or so I had imagined. Did you leave the other modules modified when you loaded your tune?
Yes, IPC Quick Boot (No Ford animation shows on cluster) was what I meant by splash.
BCM stuff on mine:
Auto start stop off
Double horn honk disable. (I also have push button, I mentioned key by habit!)
Panic alarm disabled (I have small kids)
Intrusion sensor enable (planning this)
Powerpoint timeout disabled
I think global window open/close is tied into BCM. From the spreadsheet...
Global Window Open/Close
BCM 726-17-01 0101 0101 014A
BCM 726-17-02 0101 0101 014B
BCM 726-30-01 0101 xxxx xxxx
DDM 740-05-01 Dxxx xx
PDM 741-05-01 Dxxx xx
I can do without most of these but some are a must. (DHH)
Auto strt/stp is no brainer-- put back and then the tune takes care of that.
You are totally right on windows. I was looking/referring to the autofold mirrors..oops. I know I did change that one too.
Put it this way— if it has BCM attached then be safe and change.
Intrusion sensor..? Thought it’s already active with our trucks—gives option when shutting down on the inst. panel..
Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
Intrustion sensor is for the add-on shock sensor which needs to be enabled through Forscan after installing. The one mentioned in the inst. panel is the interior motion sensor.
highway420
You know, I've been wondering about this.. So, inside is like the ol' invisible radar/microwave for convertibles back in the day? I tried to leave windows open and then wave inside the truck or even sit inside and move around to set off.. didn't seem to work. So I'm confused as to how these alarms work. Is just the door triggers then?
Do you know where the shock sensor gets installed/plugged in then? Just add it to the list of things they 'should've installed' with the cost of our truck I guess
highway420
And how is this motion sensor triggered? Sure we have this with the 802A? Thought we do and I've tried several times to check it.. Like I said before, I sat in truck, waited few minutes.. also windows down and came back to truck and poked way into the truck as if I was grabbing something out of the cup holder, and nothing. :emotions122:
Kahuna
I have had the kids set it off while inside but I have never really played with it.
