Jacking up a Raptor dos/donts
BIZZnice
BIZZnice
Raleigh, NC
I've got some 2x12s to drive up on I didn't think of that. I would definitely feel comfortable without jacking it up but I'll give it a shot without for this time next time around I'll look into ramps
Trick.Raptor
The Cracker Raptor
Santa Maria, CA
Read the reviews, lots of crushed ones. Just putting it out there
Yeah I saw those myself... I bought them in early 2013 so some of the later 2013 complaints I didn't see.
After reading some of them it appears more user error. One guy had one wheel on a ramp the other on the ground and stated the rear of the truck was over 9000lbs.
As always use caution when under your truck!
Prybar
Anchorage, AK
I have the Blitz brand poly ramps. They are great and I don't see how it's possible for the weight of a regular passenger car or truck to crush them.
t_j
Chicago, IL
I have ramps and use them with my truck, they are rated for 16000lbs I see no problem with them and doubt they would crush without some serious misuse.
Hoverp
Central Montana
I use plastic ramps, perfectly fine, they have a weight rating on them that is way more than out truck.
I drive up in 4Low , makes it real easy to control , also, after you pull up, put the truck in N and let it self center on the ramps, then go to park and set the parking brake. Make sure you let thetruck sit for a few hours after driving it up so all that oil in the top end can drain backdown to the pan before you change it.
Don't forget to check roof clearances if your in a garage also.
carlschmarl2
Chagrin Falls, OH
I bought a 10' 2x12 and cut it half. Then I use some some wood blocks for elevation.
---------- Post added at 03:50 PM ---------- Previous post was at 03:46 PM ----------
:ROFLJest: Lol....Not sure if serious or not...
Hoverp
Central Montana
I was in theory talking to a guy that had never driven up ramps before.
It's easier to control throttle movement in 4 low, ever get to the edge of your ramps in your small garage and have to throttle up to get up the hill?
When your workbench is right there in front, 4 low makes it much more controlled. Also as for the rest of the post , I was just relaying what I do. Not trying to talk down to someone .
