Recalls are for safety issues. Not hub disconnect noises that can easily be resolved by any competent service technician.Yup, pretty much identical experience on my end as well. I have an extra check valve that I'll likely install. My dealer ordered new solenoids as that was the only thing that wasn't replaced in the last TSB. He said if the noise comes back, then he'll condemn the front end and do a full replacement of those parts. I would think a recall would at least be in order for those trucks that have the symptoms.
It’s a simple vacuum operated system. It has a single solenoid, a reservoir, a check valve, and lines that go to each IWE. If you get a grinding noise on acceleration in 2WD, you have a leak (solenoid, line, or IWE) or a bad check valve. The system can be diagnosed with nothing more than a vacuum pump/gauge. The Workshop has a comprehensive diagnostic procedure that allows root cause to be easily isolated.
