Lukeclement
At 113k miles my 2011 started to sound like it was “kicking a Tin can” down the road. After a little research I found the vacuum line to the IWE on the passenger side to be cracked. Luckily ford failsafe with no vacuum is to 4WD. So I could drive it around in 4WD if needed without the “tin can” sound.
I ordered up an entire new vacuum line for the front of the truck and iwe valve.
Ford BL3Z7A785A - OEM Part https://www.amazon.com/dp/B01FL4ACWA/?tag=fordraptorforum-20
9L14-9H465-BA 6L3Z-9H465-A 7L1Z-9H465-B Vacuum solenoid valve NEW Fit For FORD F-150 Lobo F-250 Expedition 2005-2008 https://www.amazon.com/dp/B07MLZG71B/?tag=fordraptorforum-20
But it was too short by 4-5 inches on each end, I was able to save the old rubber hoses and splice them in, which actually helped since my truck is mid perch.
It took about 30 min to swap the line and valve out.
No more “kicking a can” sound and gas mileage is back up!
