Is the valve train ticking noise always Cam Phasers?
RaptorVette
Corpus Christi, TX
I started my truck this morning and instantly got a loud valve train ticking noise. I shut the truck off and checked the oil and it was about 3/4 of a quart low. I added oil, started the truck and the ticking noise went away.
Does that sound like cam phasers? Can the dealership diagnose the problem without the noise present?
FordTechOne
Detroit
How long did the noise last on the initial start? If it was more than a few seconds, it’s not cam phaser related. The dealer needs to verify a concern to diagnose it, so if the noise went away they they won’t be able to.
Sgt Beavis
Colorado
It's more of a rattle than a ticking and as FordTechOne said, it only last a couple seconds. It's loud too. Also, it only occurs when the engine is cold. So let it sit overnight and try again. You very likely won't here the rattle sound on a 2nd start.
RaptorVette
RaptorVette
Corpus Christi, TX
Thanks!
Thanks! I shut the truck off as soon as I heard it. Cold start and I'd say it lasted about 30 seconds. It's sounded like my 2015 Viper, just loud ticking. It's completely gone away now and the truck is driving fine.
RaptorVette
RaptorVette
Corpus Christi, TX
Thanks! I'll see what happens when I start the truck tomorrow morning.
goblues38
STL
cam phasers has a rythmic ticking...that would speed up if one where to hit the gas. waste gate rattle is very random and not rpm dependent.
RaptorVette
RaptorVette
Corpus Christi, TX
I'm happy to report that the loud ticking noise has not come back. Maybe it was because the oil was low and I'm 400 miles away from changing it. (Mobile 1 every 5k miles)
