RaptorWhoSaysNI
Can someone confirm that the beadlock ring on the gen 3 37PP is functional or not? Looking for someone who actually works for Ford or can show me where it states it either way. Thanks in advance for any help.
Not trying to be a wise guy here, and I appreciate the input, but I did all the research and need to hear directly from Ford or a tech that works for Ford that knows.The wheel is beadlock capable. It comes with a "beauty" ring that mounts on the wheel. If you want the wheel to be used as a true beadlock, you have to purchase the true Beadlock rings.
See Ford Performance link below. These are the true beadlock rings you buy that can bolt to your wheels to be used as a true beadlock.
F-150 RAPTOR/BRONCO RAPTOR/RANGER RAPTOR FUNCTIONAL BEAD-LOCK RING KIT
F-150 RAPTOR/BRONCO RAPTOR/RANGER RAPTOR FUNCTIONAL BEAD-LOCK RING KIT|Ford Performance Partsperformanceparts.ford.com
If you're only going to accept an answer from a Ford tech, then maybe you should direct that question to your local Ford tech, instead of a public forum?Not trying to be a wise guy here, and I appreciate the input, but I did all the research and need to hear directly from Ford or a tech that works for Ford that knows.
Called Ford Performance and they gave me the answer I was looking for lol. Maybe they are my personal servant?? hahaWell Antho gave you the correct answer. Ford isn't your personal servant here on FRF. Call Jim Farley
