GEN 1 Interior water leak.
jeanco
2019 scab=gone,24 AMB 801A
OR Beach
AC is leaking,need to be fix?
EricM
OHIO
If it's not a clogged sunroof drain, check the GPS antenna on the roof. It's located in that area and is a known leak point.
Given you are in Houston- that antenna/seal has lived a hard life in the sun.
Irregular F150
Irregular F150
its terrain good sir!
a small town in way up northeast
Carpet is dry under the weather tech so i dont think the ac is leaking. Worth a check anyway
Irregular F150
Irregular F150
You talking to me? Im pretty far from Houston LOL.
Yeah im thinking it is that but I couldn’t get it to replicate when i used the garden hose at work. Gonna seal it when i get a chance.
EricM
OHIO
I was reading the quote above my post- that guy was in Houston I guess. The leak is still going to be from your GPS antenna if it's not a clogged sunroof drain, no matter if you are in Houston or not. :)
You can look into the "gap" with the sunroof open and see the bottom of the antenna. Have someone pour/spray water on it (in a direction facing away from the open roof obviosuly) and you will be able to see the leak.
John813
PSL/Jupiter
So, had the issue on a Gen 2, dealership tried the drain tubes but they were fine. Ended up being a seal. Sunroof assembly collection tray one was replaced and the leak was solved.
A few hard rains later, and it's still dry.
P4SHOCAT
Glenside Pa.
We had a hard rain last week and my 13 had a small leak from the same place. I'm afraid of opening the sunroof, since it has not been opened from 2019 when I bought the truck. Was only a few drops so I may just leave it be. I don't want to break the sunroof.
