GEN 2 Installed SVC's Coil Adjuster System
shelteredraptor
on a rock
that drone shot is ****** awesome Tizz. The guy on the ground napping missed the shot? I got a launch shot, but it's off the 16th tee at a golf club in Mexico with a telling landmark in the background, so that ain't making the interwebs... and yes, the ground was decently frozen so no real damage to the turf
JSTi07
Truck looks great and I'm glad to see it being put to use!
Could you add some pictures of what you trimmed initially to get the 37" tires to fit?
Raptizzle
Raptizzle
FYT
Southern CA
Thanks, I didn't trim anything running 37" KO2's.
So you're happy with the 37" KO2s? I'm thinking about picking up a set next week.
Oh yeah, they're a great all around tire and fit the wheel wells nicely at full bump with the @svc CAS system dialed at a pretty comparable height to where I have mine set.
svc
Worldwide
Here 's the video of Tizzles truck beating up the new C.A.S. system. We are pleased to announce it worked just as expected. No rubbing anywhere against the tierods or axles, helped keep the front end of the truck up and is a must for guys wanting to run 37's. Like all springs, they will settle after some use. We are gonna run it as is for a little bit, take some measurements and adjust as needed down the road.
We must admit, everyone cringed a little watching a brand new 70K truck take the pounding it did, but it was in the name of science so we can all deal with it.
Huge thanks to Raptizzle for being the first test dummy of the system.
The only changes we decieded to make for production was to narrow up the lower section of the threaded perch body so the Fox stickers shows better.
Hope you all like the video.
Jarrett
https://youtu.be/HyQoPZ9vBpg
Deleted member 12951
Guest
How did the alignment come out, was within specs? Or was camber or caster higher/lower?
Tonecapone
Jarrett
Great video, kudos to the drone work.
Tone
