here are some pics from a few weeks ago where Raptorguy21 and I installed my rock guard for my rear differential. This product is made by Purple Cranium Products and is known as their Ford Raptor 9.75" Full Spider Rock Guard.
For those considering something like this, I would like to point out that this thing is very heavy. If the weight is a concern to you, there may be more lightweight options out there (I'm not sure, but I would imagine a Mag-Hytec diff cover is lighter, for example).
Personally, I like knowing that a rock or stump has to break into Alcatraz before it can damage the proverbial ******* to my driveshaft, but that's just me.
The weight doesn't add a difference that I can feel in the driver's seat, but I still know its there. If it were much heavier than it already is, I may not have put it on... but I think the thing looks awesome too, and that was a bit of a saving grace that offset the weight factor for me.
First you'll need to remove your spare. Break out the kit under the seat and put the shaft of the crank into the uncapped hole in the bumper :********:
Lower your spare by cranking it down to the floor and removing the cable. If you don't know how to do this then RTFM definitely ought to be your first order of business.
__________________________________________________
Next you'll need to remove the hardware from your rear diff.
Don't forget about this lil' guy up here....
Don't worry about fluid leaking or the plate coming off, the gasket seal will hold it all together while you have the original hardware removed.
Now align the Spider with the holes left by the removed factory hardware,. and hand tighten the new supplied hardware to get the rockguard in place.
I recommend starting at the corners since this sucker has some weight to it.
___________________________________________________
then crank them puppies down and put some stank (torque) on 'em....
____________________________________________________
don't forget to put this back....
_____________________________________________________
Now raise your spare tire back into place....
......and you're Golden.
Diff protected. A little "Cover Your Ass" helps ensure that a man sleeps peacefully at night. Total install took about 30 minutes at a leisurely pace.
If you are interested in ordering this product, you can do so in a variety of powdercoat and decal color combinations at this link here: http://purplecranium.com/i-63369-ford-raptor-9-75-full-spider-rock-guard.html
