Installed new model TurboSmart BOV kit
BlackEvo
Nor-Cal
So your saying the electronic stock BOV is better?
Performance wise vs. A VTA set up, yes. The system was designed to vent internally, so removing that air from the system can cause some loss of performance. Some people really dig the sound, so if it's wort it to you .... .
There are companies that make internal venting BOV. Go Fast Bits (GFB), make an adjustable BOV so you can vary the amount of air vented to atmosphere. Kind of the best of both worlds. I don't know if they make an application for the Raptor. Just some stuff I learned from the import scene.
Jayrod
FL
Performance wise vs. A VTA set up, yes. The system was designed to vent internally, so removing that air from the system can cause some loss of performance. Some people really dig the sound, so if it's wort it to you .... [emoji106][emoji106].
I've had several turbo vehicles and always understood a mechanical to hold boost more efficiently.
xgardx
xgardx
CLE OH
Have you had to adjust the setting on the BOV at all to make it "harder" or "softer"?
Curious where your setting was at when you received it?
The nipple is just covering the letters "har" in the word "harder".
i didn't touch it from where it was sent to me from factory, figured the option was there incase you decide to raise the boost pressure and need it to hold higher PSI, vs being more reaactive at a lower /''factory'' boost level.
---------- Post added at 04:24 PM ---------- Previous post was at 04:16 PM ----------
hmmmm this is interesting to learn. I figured between the factory and aftermarket VTA, you'd be keeping the turbos spinning faster/at a higher speed, by letting the excess boost bleed out vs. reintroducing it and causing turbulance into the intake piping, especially the way it dumps back into the line at a 90* connection point/and or increase in surge time back against the intake turbine wheel vs the delay in the factory BOV.
nah_tan
Just did the install. Super easy! Took just under two hours and didn't even need to jack stand/lift the truck. spent most of my time cleaning the threads out of the damn boost tap to get the nipples and plug screw in there. Sounds great!
Trashguy
finally did mine, I had the vta mod for awhile prior to this and this is much louder and frequent.
loving it.
hkguns
I get a shit load of swoosh from my stock turbo setup.
I have a video posted driving and you can hear it very clearly.
