GEN 2 Installed my Ford Raptor Lights Kit!
JefferyBasham
I thought it was me, I had a hell of a time mounting the steel bracket. Then the washer stack up was not right for me. I had to add washers to get the light to the correct height. Not I big deal but it was frustrating. Other than that, I love the lights. I run the amber without getting flashed. bef444eb08ffb512a9082c9b2f280388.jpg
Sent from my SM-G955U using Tapatalk
OffroadAlliance.com
Boston, MA
What did you add to the stack? Be easy for us to as a few washers if you found that was needed.
Nibbl3s
Awesome. Would you mind going into a bit more detail on how you routed the wires. Also, did the pre wiring that came with the kit wire it so that pairs could be connnected to one switch?
Thanks
JefferyBasham
I'm not sure, I had a mixed bag of nuts, bolts and washers from other projects. I just added until the lights were the proper height.
SpeedJunkie
I got my kit yesterday and started the install. So for so good, really nice kit. Got the brackets installed and the KC lights mounted, but nothing wired up yet. Will probably have to finish it up this weekend.
I do have a question though. I would like the Baja lights wired in through the high beam switch, so that I have to have both the AUX switch and high beams on for them to come on. Is that possible? If so, how?
