Installed Foutz Motorsports Rear Coil Spacers!
Rengastarr
Santa Barbara, CA
Hey all, so I ordered the Foutz Motorsports 3/4” rear coil spacers. I have the 2.25” RPG collars up front, so needed to raise the back a little. With limited options, I was so stoked to find these spacers to get the stance right and help with the sag while towing. I called and they had a pair in stock! Besides the cosmetic and towing benefit, the truck actually feels better with the ass a little higher then the front. I even had to readjust the seat it was such a noticeable angle. Anyone who has the 2.25” collars, these things will do you good!
D5643611-FF24-4C23-9D05-A7B094119B74.jpegF4AF3AF2-5D27-4F34-8B6D-077156A9AA01.jpeg3FF46F16-C6CC-4413-B435-052AECF5FC11.jpegF13968E9-E5A3-49F7-BDDD-0D48B94EEEF4.jpegEC1E0A62-5511-4733-93CF-2BE315BEE193.jpeg
Floyd554
Belle Vernon, PA
I was just looking through Foutz site. I did not see these listed. Do you have a part #, price, difficulty of installation? Truck looks real good. Has it changed the ride quality? I was gonna wait for a full 4 corner spring setup from Eibach or Geiser, but I may just go with the spacers. Like to hear more of your thoughts. Thanks for posting.
Rengastarr
Rengastarr
Santa Barbara, CA
See below, it has the part number and all the details. I had a shop install, but they did it real quick, I think it took them about 60-90 minutes. I’d like the new springs like you mentioned as well, but there’s not even a guess as to the ETA for those. I talked to Custom Spring Specialities, but they need to get their hands on an OEM spring to develop off of, and I don’t want to mail them mine and have the truck off the road for however long that takes. These spacers worked great so far, heading to Pismo in a week and a half, so I’ll put them more to the test and report back. The ride was greatly improved just getting the truck to sit at a more correct factory stance. The steering and the body movement seems more nimble and definitely improved from having the 2.25” front, and just stock in the rear. I vote with it for sure, and will report back anything otherwise!
Also they have a 3/4” and a 1” options. I went with the 3/4” and was plenty for my setup.
BCR7
Utah
I have 2021 on 35s. Installed Foutz 2 inch front and 3/4 inch rear. Front and back are dead on 42 inches ground to bottom center of fender. Perfect set up and dead level. Foutz told me this is recommends recommended set up if not loading gear in bed. They are correct. Get one inch in rear if installed gear in bed.
riv
illinois
lets see a picture
Rengastarr
Rengastarr
Santa Barbara, CA
are those pics on a level surface? how do you like those tires for everyday driving??
The parking spot is slightly sloped down away from the wall for drainage, but not much. I’ll see if I have another pic on flatter ground.
The tires are a 10/10, very impressed!
