Just installed the 2021 Rear Baja Design S2 Reverse Light Kit w/ long harness I got from @Specialtyperformanceparts . Very pleased with kit especially the custom harnesses and customer support from John. Like how the BD S2P tuck up high and under the rear bumper.
My GEN 3 is a 2021 order delivered in Jan 2022 and I don't know how consistent the builds are so you might have a different setuup/experience.
I posted some comments and pics about having to remove the battery in order to crimp the AUX wires. https://www.fordraptorforum.com/threads/help-problem-with-upfitter-switches.88683/post-1743892
TIP - Mounting the S2Ps. Insert the mounting bolt thru the bracket. Attach the S2P to the bracket FIRST (I followed John's advice regarding bracket orientation), then attach the assembled light & bracket to the truck. I initially loosened the bolt on the truck with a T40 and impact drill and reattached using a 3/16 allen wrench and was able to crank it down.
Ground location - I could not find any pre-existing grounded wires anywhere near the grounding wire other then a huge grounding wire and bolt so I used a 3/16 allen wrench and used the bolt show in the pic which is between the right rear tire and the spare when underneath and looking at the inside of the rear bumper. The entire bumper/frame is grounded so it will be fine.
In addtion to being tied into the regular reverse lights, the long harness from @Specialtyperformanceparts allowed me to wire it to AUX 6. The S2Ps draw 1.7A each, the switch is rated for 5A and I wanted the far right AUX switch to control the reverse lights. (AUX 1,2,3 will be controlling the 3 light BD fog kit I have coming).
Room for an allen wrench
Grounding location
Grounding location
