Install of H&M Long Travel
R
RyanFelish
See Updated posts..
Also, if you can't tell I am slow getting around to updating the thread, follow me on Instagram for more frequent pictures and updates. Frame mounts will be here tomorrow so it should start picking up.
@RyanFelish
R
RyanFelish
Updated again.
Side note, the wood under the axle is not supporting any weight. The truck has 6 heavy duty jackstands under it. I had to use the wood to keep the axle high enough to put a block on my jack so I can bottom out suspension.
More to come. I have a week long Mexico trip starting this weekend so I won't get too far too quick.
I got all the stuff to brace my lower arm pockets, so I can get the lower control arms installed next garage day. I also cut holes through the bed for my bump stops, started building my bump pads, and can soon figure out the rest!
King Shocks still aren't here..... Hopefully I come home from Mexico with some boxes in my garage...
R
RyanFelish
Updated with a lot more pictures.
Kings are finished and should ship tomorrow.
Alignment is done except for toe in.
IWE lines and speed sensors ran up front.
Bed cage started, once shocks come I can design the rest.
Lots of help from this cutie.
R
RyanFelish
Lots more pictures and progress added.
Hopefully driving it around the block this week sometime. Needs a successful brake bleed and front coilover install.
The longer it takes me to update this thread is directly related to how many hours I am putting in the garage. If you want to see more frequent updates follow me on Instagram. RyanFelish
