Ryan C
Thought I would share some ideas for how to wire XL80s on A pillar mounts and an 30" onx6+ bar on the bumper. I had the xl80s on my last truck, but hadn't wired a relay before. I'm obviously not a pro, so please let me know if I should adjust anything or you have other tips for me or others!
First, here's a pic of the truck as it sits now.
I purchased crimpers for the weather pack connectors, https://www.amazon.ca/dp/B0732W6HQR/, and also got the hollow weather pack release tool from a local auto parts store.
I then cribbed together some wiring harness parts from what Baja Designs supplies, so that I could run the right lengths from the lights at the A pillars down to the location of the upfitter behind the battery tray, without excess lengths or overlap. I attached a 2 slot weather pack to one of the upfitter wires (15A), and made the connection to the harness from there. Note I had to remove battery and battery tray to get the up fitter wires out. The ones with power are wrapped with red tape on my 22. I ran the ground from the lights back to the ground right behind the battery, and through the weather pack connection so I can disconnect the harness easily at that location. I used 16ga wire, which may be a bit light TBH given the length and power of these lights. I used heat shrink where possible. You can sort of see how I did this in these pictures.
