Increasing amps of upfitters
OBXRAPTOR17
Forgive me if this has been posted- I searched and couldn't find anything on this forum.
Is it possible to change the 5A up fitter to a 25amp switch by using a 25amp rated relay and appropriate 25amp fuse? I know this can be done on F-250s but haven't seen it mentioned on the raptor. A 20 am circuit would also do....
thanks
solarwinds
DFW
thanks
good question.. other than the wire gauge would be interesting concept
Ironhorse07
Central, MT
No, the wire gauge is too small. You need to add another circuit and relay, in my opinion, this was stupid that there is not at least one or two 25 amp upfitters.
OBXRAPTOR17
OBXRAPTOR17
In the scenario I am asking about, the 5A upfitter would only energize the coil of the relay. The relay would be rated to 30A (for example) and all the wire going in and out of the relay (except lead for coil) would be gauged for 30 amps with inline fuse- would THIS work? the 5A switch and the wiring harness of the vehicle would never see 30A, correct or incorrect?
thanks
yes, that can work wired properly. I did this with my behind the grill lights. I believe there are a few posts describing in some detail, if you don’t have a kit with instructions.
solarwinds
DFW
thanks
o ya. thats what i did for some of my rigids. the upfitter is just used as the switch.
i thought u were saying before u wanted to replace ford oem relays and fuses.
shelteredraptor
on a rock
Yup. You're just using the factory wire as an energizer, and can be as little as 2 amps. I already have 2 relays on there, someday I'll tidy it all up like some guys did in the gen 1 upfitter threads. Some nice work done there.
OBXRAPTOR17
OBXRAPTOR17
yea- i didnt frame the question very clearly- thanks for the help.
