GEN 2 I'm a little concerned with these Gorilla Lug Nuts, they don't seem wide enough. Anyone else try these on OEM wheels?
fordrat
us
They don’t look trustworthy to me mainly because if you go off roading and hit a rut or something could be bad
D
dsiggi
Guest
You need bulge ones from Goriila, note they changed their bulge design a couple years back and they are still the same conical shape 60 degrees as OEM but the bulge is not as large. I fought with goriilla about it for a while and they said they changed the design. The larger bulge allows the nut to seat better and not tear up your wheel. The new design had to be near perfectly fit into the wheel square when applying torque, nearly impossible to do.
